Instruction Template Manager?
Options
DanS
Where do I open instruction template manager in 2008?
Thanks,
DanS
At the home tab you will find a tiny!!! arrow in the lower right corner of the path programming group.Per Svensson
Consat Engineering0 -
You can also open it from the menu of the status bar that appears when you selected the currently active instruction template.
ABB0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 345 IRC5
- 73 OmniCore
- 843 RAPID Programming
- 20 AppStudio
- 107 Collaborative Robots
