PERS structures initialization
Hello all,
We have prepared several PERS structures, those structures have been declared as PERS as they must be shared between the 4 robots that form our multimove system.
The problem here is that when we load a new program, with different values for those structures the values are not being replaced, and a messagebox appears on the flex pendant telling us that the values have not been updated.
Can I have the values updated in that situation somehow?
I'd like to be able to load a program overwriting the actual values in the flex pendant with the ones saved into the program file.
I think I remember that this should work in that way... could it be that it fails when structures are involved?
As always thank you in advance.
Joan2008-8-15 13:13:12Comments
Solved...
Our mistake, as we have four robots and the structures have different values during the loading of the modules/programs, the values that exist on the robot memory are kept.
In order to get the new values loaded we need to unload the program/modules and reload them.
Thank you for reading!
- 5.5K RobotStudio
- 398 UpFeed
- 19 Tutorials
- 13 RobotApps
- 299 PowerPacs
- 405 RobotStudio S4
- 2.8K Robot Controller
- 324 IRC5
- 63 OmniCore
- 813 RAPID Programming
- 6 AppStudio
- 3 RobotStudio AR Viewer
- 105 Collaborative Robots
