Attach Object Frame to part
Is it possible attach Object Frame to part so that the User Frame does not move when you move part (and Object Frame).
Petri
  • Hi,
    If you attach the object frame to a part, and move the part. Then the user frame will move too, since the user frame is the child of the object frame.
    What you need to do is to (1) attach the workobject to the part, (2) put the part where you want it, (3) select to "Modify Workobject" in the browser, and (4) expand the user frame and finally (5), put the cursor in the "set position" coordinate edit box, and (6) click in the graphics where you want the user frame (you can also enter the number by hand if you know them).
    ABB
