SDK Error Constants [WebWare SDK]
Is there a list of constants for the error numbers, eg, -3113 is a "Directory does not exist". I can get the error string, but just looking at a list of constants so I do not re-create them.
  • Hi,
    can you please explain your problem again, I don't fully understand what you want to accomplish?
    If you want them manually then you have them in the [Installation and Setup Guide] chapter 4.
    If you programmatically have the number but want the description then you can use the Helper.ErrorMessage(errorcode) function
    Here is a short example:
    intRetVal = Helper1.S4ProgramVariableRead(Text2.Text, 0, myArray)
    If intRetVal <> 0 Then
    Label1.Caption = Helper1.ErrorMessage(intRetVal)
    Exit Sub
    End If
    It would also be possible to do something like this:
    Label1.Caption = Helper1.ErrorMessage(Helper1.S4ProgramVariableRead(Text2.Tex t, 0, myArray))
  • That's what I am doing. What I am looking for are constants for the actual error codes. What I am forced to do at present is to create a  constant for each error# (rather than use "-3113" atl the time). Example...
    Const SDK_ERR_DIR_NOT_EXIST = -3113
    sdk_status = ilinkRobotHelper.S4Dir(ilinkRobotHelper.DevList(0), edtDeviceDir.Text, SDK_UNIMPLEMENTED_ARG, 3, lResultID)
    If ( SDK_ERR_DIR_NOT_EXIST = sdk_status) Then
        msgbox( ilinkRobotHelper.ErrorMessage(sdk_status) )
    end if
    thanks,
  • Ok, now I'm following. image
    I don't think there is such a list of error number constants. Sorry.
