variables
Hi all,
I've got a problem with the RobotStudio. Maybe, there is everyone who can help me.
The problem: I'm connected my PC with the controller (IRC5) and see all the modules and programms. I declared num variables as PERS for count the produced parts. The value of the variables will not be refreshed. Is there everywhere a button for refresh the values?
or How can I view the "programm data" menu from FlexPendant on the RobotStudio?
Hi C.
Have same problem. They dont update i the rapid edition Off or Online. ANd to see severel on FP takes time. I have made an RAB interface in VB.net to monitor the variables i want to see during test and programming. have a projekt with a lot of recipe data that i use.
You can use rapid watch in RS 5.11 but i does refresh proberly
Best regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
The Watch Window (rapid watch) in RS is only updated after program stop.
ABB Robotics0 -
is it possible to solve the problem with an interrupt routine to stop for a moment the programm flow?
Hi C
Do you have PC interfase option on your robot
Best Regards
Klaus Soenderhegn
Hi klaus,
unfortunately we don't have the PC interface option. Have you got a solution which use the PC interface?
Hi again.
Yes i have made i small App in RAP to monitor my variables during running both on VC and real robot.
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 38 AppStudio
