Added users may not be saved [WebWare Server]
If you make changes to the default web site configuration by adding users or roles, your changes will not be saved if you press OK in the User Definition page but don't press Apply on the Site Settings page before exiting that page.
In this sequence, the changes will be reflected in the Users ListBox on the Site Settings page but are not yet committed to the webware.config file. The webware.config file is not created until a non-default setting is saved. This behavior is by design.
To avoid losing changes, either press Apply on the User Definition page or press Apply on the Site Settings page before exiting.
Russell Drown
