Installing RS5.11
When Installing 5.11, should I expect any problems with existing stations and virtual controllers? <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I.E. uninstalling 5.10 first
Will I loose information?
Does it use the same library folders / media pool?
Will installing overwrite existing files?
Is licensing done in the same way?
Many thanks
Smile
  • Hi
    Have you read the release note Wink
    Installation
    RobotStudio 5.11 will automatically upgrade any existing installation of RobotStudio
    5.10 or 2008. Any previous installation of RobotStudio Online will remain untouched.
    How to migrate from RobotStudio 5.10 to RobotStudio 5.11
    All your existing stations, libraries, geometries, controller systems, and add-ins can be
    directly reused in RobotStudio 5.11. RobotStudio 5.11 is compatible with previous
    releases of RobotWare (see also section Known Limitations).
    Note: Stations or libraries created in RobotStudio 5.11 cannot be used in RobotStudio
    5.10.
    Regards
    Knud Erik Lindberg
    Jorgensen Engineering
  • Hi,
    The licensing system of RS 5.11 is replaced. The reason is to enhance user experience.
    ABB
