Flexpendant Application Install
Hello all,
Simple question... How do I actually install and run a RAB designed application in a Flexpendant. I've built the project and copied the '.dll' and 'gtpu.dll' files into the controller itself under the Home directory (I've gathered that much from the user guide.pdf). How do I now run this application?
Thanks in advance for your help,
Ben
  • Never mind.
    I think the fact that I don't have the "FlexPendant Interface" Option enabled in the controller has something to do with it image
    Will try that first.
  • You are absolutely right that You should have a system with Flexpendant Interface option and also after putting the ".dll" into HOME folder of the system , you must restart the FlexPenadant
    Sunil Sabut
    India Corporate Research
    ABB - India
