ApplicationError RobotStudio
Options
have some problems with opening any Station: after opening any Station an Application Error occurs and the Dumb-File contains:
RobotStudio debug file.
Main Thread ID: e54
Crashing Thread ID: 90c
Exception Address: 189f1836
Exception Thread StartAddress: 7c920760
Crash time: 8089842
   Type:CM_DEBUGSTATE_APICALL Time from crash:12177 ms State:ABB::Robotics::RobotStudio::ProjectSelection::Contains
   Type:CM_DEBUGSTATE_SIMSTATE Time from crash:36783 ms State:LG_SIMULATOR_STATE_READY
   Type:CM_DEBUGSTATE_UNDOSTEPNAME Time from crash:36653 ms State:Als aktiv festlegen
Done! 3 entries.
DebugInformation:
    127123  Key: MainGUIThread  Value: e54
    60217  Key: Executing Command  Value: FileOpenStation
    35371  Key: LgVCHelper::ThreadFunc  Value: ff4
    12818  Key: Executing Command  Value: Done
    9884  Key: ExceptionHandler: Caught exception in OLE thread. It sleeps with the fishes.  Value: 90c
Done
what can i do? Anybody any Idea?
Thanks for your Help!
best Regards, Volker
  • Hi Volker,
    What RS version are you using? I suppose it is 5.10 or 5.09. If this is what I believe it is, this problem has been solved in RS 5.11. It may help also to just install the "Robot Communication Runtime" for RobotWare 5.11 that is available in a folder of the RobotWare 5.11 DVD. It can be downloaded from the RobotStudio Community (www.robotstudio.com/community).
    ABB
  • Hi Henrik,
    Thanks for the quick answer. Just installed the Robot Communication Runtime and tried again - but had a pretty similar Application Error:
    Main Thread ID: e60
    Crashing Thread ID: f00
    Exception Address: 18be1836
    Crash time: 554317
       Type:CM_DEBUGSTATE_APICALL Time from crash:20079 ms State:ABB::Robotics::RobotStudio::ProjectSelection::Contains
       Type:CM_DEBUGSTATE_SIMSTATE Time from crash:35511 ms State:LG_SIMULATOR_STATE_READY
       Type:CM_DEBUGSTATE_UNDOSTEPNAME Time from crash:35371 ms State:Als aktiv festlegen
    Done! 3 entries.
    DebugInformation:
        182793  Key: MainGUIThread  Value: e60
        61008  Key: Executing Command  Value: FileOpenStation
        34039  Key: LgVCHelper::ThreadFunc  Value: f54
        20440  Key: Executing Command  Value: Done
        10856  Key: ExceptionHandler: Caught exception in OLE thread. It sleeps with the fishes.  Value: f00
    Done
    Now, i will install RS5.11 completely and try again.
