I/O Simulator in Auto mode
Kevin
When I try to simulate inputs in Auto mode I get the message: 'Failed to set value for signal ....., check access rights.' The I/O simulator works OK in Manual mode.
I need to test some logic which responds differently to inputs depending on whether the controller is in Auto or Manual mode.
Where must I look to check access rights, and how can I grant the I/O simulator access rights in Auto mode?
Thanks for any advice,
Kevin.
Kevin.
Hi Kevin,Ensure that your signals are configured with Access Level = ALL and not DEFAULT (which is the default...)Henrik Berlin
ABB0 -
Thanks Henrik, that fixed the problem.
Kevin
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
