Changing UCS
spaik
Hello..
When I make something in RS such as a box, UCS is located at the corner. Can I change the position of UCS to the center of the object?
Best & Kind Regards,
spaik
spaik
It's not possible to change the UCS of a part that you have created in RS. What you can do if you want to use the center point as a reference (for example rotating around):
- Create a target in the center point of the part.
- Set the target as UCS.Per Svensson
Company Specialist
ABB Automation Technology Products0
