Lin & RobotStudio 5.07
I have RS5.07 version and I downloaded RAB 5.11 version.
Can I develop RAB for my RS 5.07 version?
If not, should I upgrade to RW 5.09 or 5.10 and develop RAB for that.
Please guide me. Thank you in advance.
Hi Lin,is RS = RobotStudio????There has been a lot of changes since 5.07 to 5.11. As an example, 5.11 includes a new set of controls. I will use at least Rw 5.10 and RAB for a good start.BR/CarlosCarlos Martinez
ABB0 -
If I have RS 5.07 then can i upgrade only the RW.
Means I have RW 5.07 with RS 5.07 and only install RW 5.09.
can i do installation only 5.09 to RS 5.07?
Lingaa0 -
[QUOTE=Lin]I am new to RAB forum.
[/QUOTE]
[QUOTE=Lin]If I have RS 5.07 then can i upgrade only the RW.Means I have RW 5.07 with RS 5.07 and only install RW 5.09.
[/QUOTE]Dear Lin,
Please note that the only way to still have an external version of RobotStudio 5.07 is to have installed the cracked version.
Something which is a punishable offence. I would sincerely recommend that you uninstall it, since so far the cracked versions that we have tracked down all install trojans.
To answer your question, no you can not install a later version of RobotWare on top of your RobotStudio version to make it compatible with Robot Application Builder.Best regards
John Wiberg
If you don't know what a trojan is please read this:
http://www.microsoft.com/technet/security/alerts/info/virusrat.mspxJohn
Developer Center0 -
thank you Mr.John.
I uninstall Robot studio 5.07 and using 5.10 now.
Thank you very much.
Lingaa0
- 361 IRC5
- 79 OmniCore
- 853 RAPID Programming
- 30 AppStudio
