About "Michanism joint jog" Window
Rafeal
Can I let the "Michanism joint jog" Window always show. As usual ,I first open "Michanism joint jog"Window, then , if i open another one ,"Michanism liner jog"Window ,for example, the "Michanism joint jog"Window will disappear, but I want to let the "Michanism joint jog"Window show at same time ,that is important to me ,because i want to supervise the dgree of each axis when i liner jog or rotate!Is there any way to do so?Thank you!
Right click in the corner, and select tear off.Regards
Knud Erik Lindberg
Jorgensen Engineering0 -
oh!Thank you!0
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
