Robot on track and View Robot on Target
msalminen
When you have robot on track (IRBT6003F in my case), it seems to me that the 'View Robot on Target' don't behave well.
When you click/select some target, and robot should jump to selected target automatically, following happends:
Robot updates its joint values, by using new target and !! current track position !!, after that the track position is updated related to the new target. This leads that robot have wrong joint values and position. Reclicking the target correct the robot position, because the track already have correct position and the robot joint values can be calculated correctly.
'Jump to Target' don't have this problem and is working correctly.
Mika
What I know this is a known issue that is allready reported.
Per Svensson
Consat Engineering0 -
Correct, this is a known problem that will be solved to the next release.
ABB Robotics0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 338 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
