stopmove
carmila
hi,
i want to make my robot suddenly move if i press one button (di). i use trap which contains stopmove. And for making the robot moves again, i use trap that contains startmove.
here my program:
trap pause_int
stopmove;
endtrap
trap resume_int
startmove;
endtrap
the program is correct, but i only can make pause and resume only once time. after i pause the robot and resume, the robot can't be paused again.
I think, the problem is because of the PP is still in trap position (not return to main program), so when i press the pause button, the trap can't be executed.
Are there any suggestion for my problem?
thank you very much
best regards
carmila
indah carmila
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
