Simple Example
first of all, iA'm a beginner in Robot Studio and need some help.
Can anyone give me some simple example of RobotStudio RS5.11 project and Robot Application Builder project?
thanks for the help
  • Hello,
    The purpose of Robot Application Builder is to develop customized operator interfaces for IRC5. Such applications run on a PC or on the FlexPendant. Berfore starting coding you must decide which of these platform you want to create a project for, that is which of the two SDKs you want to use: the FlexPendant SDK or the PC SDK.
    The best way to start learning about Robtot Appliction Builder is to visit RobotStudio Community -> Developer Tools -> FlexPendant SDK Getting Started / PC SDK Getting Started and follow the directions you get there.
    When you have started coding and is stuck with a coding problem, the best way to get help is to turn to this User Forum. I also recommend you to use the Search function (on to of this page), to see if your question has already been answered in this forum.
    Ingela Brorsson
    Software Engineer
    ABB Robotics, Sweden
