SignalFilter
PerM
Hi Everyone,
Have a small question.
I'm trying to use signal collections as it is showed in the RAB manual (PC 5.10). But I don't seem to be able to use the "SignalFilter" as it is described on page 246.
I instead found a way to use the filter directly in the "GetSignals()" function.
I guess this also might work, just wonder if the documented way is not possible, or if I'm doing something wrong.
/PerM
