Robot Application Builder 5.11.01 released
A small revision of the 5.11 release is now available for download (5.11.01).
It will soon appear on the Community download page; until then you can get it at:
RobotStudio Community>Developer Tools >Robot Application Builder Overview.
Release Notes can be found separately on the same web page.
The following FP SDK errors have been corrected:
The reference documentation for the FP SDK 5.11 has been rebuilt.
(The red build errors are now gone.)
When a NumEditor control was used in a TpsControl, the ClickEvent
raised a NullReferenceException in Taf.exe that required the FlexPendant
to be restarted. When using the DataEditor control in a TpsControl,
it did not display an alpha pad when clicked.
These errors have been corrected.
The FP SDK PictureBox control was missing in the Visual Studio toolbox.
It has now been added.
In RAB 5.10 an FP SDK application using TpsViewStartupTypes.Automatic
in the TpsView attribute did not have an entry in the ABB menu of
the FlexPendant. In RAB 5.11 this error was corrected.
But no solution was provided for users who relied on the previous behavior
and do not want an entry in the ABB menu for applications that are launched
automatically at start-up. In this revision a work-around for this described in
the Release Notes.  (This applies also to Invisible applications.)
Ingela Brorsson
Software Engineer
ABB Robotics, Sweden
