RobotWare with 64-bit Windows
Options
I'm using:
- Windows XP Professional x64 Edition
- Intel CoreA?2A?DuoA?T9600
- 4GB RAM
- NVIDIA Quadro FX 1700M
- RobotStudio 5.11
If I try to create a new station, I'll get the following error:
"RobVCFactory.Launch failed, hr=c0040701
The release directoryC:...RobotWare_5.11.0160
is missing or corrupt, and cannot be used when launching a VC."
IA?also have the same problem with an other 64-bit-computer... Only ourA?computersA?with 32-bit-Windows don't have any problems.
Is RobotWare 5.11 working with 64-bit-Windows?
Thank you!
GA?nter
I'm using:
- 4GB RAM
- RobotStudio 5.11
Thank you!
GA?nter
OK, I've installed the new Version 5.11.01 and now it's ok...
GA?nter0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
