recursion and directory structure [WebWare SDK]
Has anyone developed any backup rutin that copies the result of a backup to the PC. The complete directory structure from robot to PC.
The problem is with the acctual recursion in the filecopying....
Would appriciate some samples...
  • Hi Svempa,
    i've written some routines to copy recursively some files and or directories, here they are:
    'This function copies a directory structure including the files from
    'a source to a destination drive and dir from a given robot.
    'Also the structure can be deleted after copying from the source drive
    'A user interface can be set up to hold status informations by handing
    'over a textbox and a label.
    Public Function S4DirCopy(Robot As Helper, _
                              SourceDrive As String, SourceDir As String, _
                              DestDrive, DestDir, _
                              DelAfterCopy As Boolean, Optional StatMessage As TextBox, _
                              Optional StatTitle As Label) As Integer
    Dim DirList() As String
    Dim NewDir As String
    Dim NewDrive As String
    Dim Sourcefile As String
    Dim Destfile As String
    Dim i As Integer
    Dim ShortPath As String
    Dim x As Integer
    Dim dX As Integer
    Dim hResult As Integer
      On Local Error GoTo DirCopyHandler
    'Setthe staus label text
      StatTitle.Caption = "Status:"
    'get a directory from the source dir
      Result = Robot.S4Dir(SourceDrive, SourceDir, 0, WAIT_ON_RESULT, ResultID)
      If Result = 0 Then
    'Display status
        StatMessage.Text = SourceDir & " read"
      Else
        S4DirCopy = Result
        Exit Function
      End If
    'If subdirs found
      If Robot.DirListCount > 0 Then
    'Get storage place
        ReDim DirList(Robot.DirListCount - 1)
      End If
    'If files found
      If Robot.FileListCount > 0 Then
    'Get storage place
        ReDim FileList(Robot.FileListCount - 1)
      End If
    'For all found sub directories
      For i = 0 To Robot.DirListCount - 1
    'Copy to a local data storage string
        DirList(i) = Robot.DirList(i)
      Next
    'Create destination dir (if it is the root then do not create it)
      NewDir = DestDir
      NewDrive = DestDrive
      NewDir = RemoveDirSep(NewDir)
      NewDrive = RemoveDirSep(NewDrive)
      If NewDrive = S4C_Ramdisk Or NewDrive = S4CPlus_Ramdisk Then
        If NewDir <> strEMPTY Then
          Result = Robot.S4MkDir(DestDrive, DestDir, WAIT_ON_RESULT, ResultID)
        End If
      Else
        End If
      End If
    'Set status info
      StatMessage.Text = DestDrive & DestDir & " created"
    'for all Files do
      For i = 0 To Robot.FileListCount - 1
    'Get filenames
        Sourcefile = AddDirSep(SourceDir, True) & Robot.FileList(i)
        Destfile = DestDir
        Destfile = AddDirSep(Destfile, True)
        Destfile = Destfile & Robot.FileList(i)
    'Set status info
        StatTitle.Caption = "Copying"
        StatMessage.Text = Sourcefile
    'Copy the file
        Result = Robot.S4FileCopy(SourceDrive, Sourcefile, DestDrive, Destfile, _
        S4DirCopy = Result
        If Result = 0 Then
    'If delete after copy then delete the file
          If DelAfterCopy = True Then
    'Set status info
            StatTitle.Caption = "Deleting "
    'delete file
            Result = Robot.S4FileDelete(SourceDrive, Sourcefile, WAIT_ON_RESULT, ResultID)
            S4DirCopy = Result
          End If
        Else
    'give error during copy
          MsgBox "Couldn't copy the file, error code = " & Result & "."
        End If
      Next
    'For all sub directories
      For i = Robot.DirListCount - 1 To 0 Step -1
    'Exclude parent and actual directory
        If DirList(i) <> "." And DirList(i) <> ".." Then
    'Call S4DirCopy recursively with next directory
          Result = S4DirCopy(Robot, SourceDrive, AddDirSep(SourceDir, True) & DirList(i), _
                             DestDrive, DestDir & "/" & DirList(i), _
                             DelAfterCopy, StatMessage, StatTitle)
          If Result = 0 Then
    'If delete after copy ordered
    'Set status info
              StatTitle.Caption = "Deleting directory"
              StatMessage.Text = DirList(i)
    'Delete directory from source drive
              Result = Robot.S4RmDir(SourceDrive, AddDirSep(SourceDir, True) & DirList(i), _
              S4DirCopy = Result
            End If
          End If
        End If
      Next
    'Set status info
        Result = Robot.S4RmDir(SourceDrive, SourceDir, WAIT_ON_RESULT, ResultID)
        S4DirCopy = Result
      End If
      Exit Function
    DirCopyHandler:
      If Err = 7 Then           'If Out of Memory error occurs, assume the list box just got full.
        S4DirCopy = True        'Create Msg and set return value AbandonSearch.
        Exit Function           'Note that the exit procedure resets Err to 0.
      Else                      'Otherwise display error message and quit.
        Exit Function
      End If
    End Function
    I have also done a routine just for deleting this stuff:
    'Function S4DirDelete deletes a directory
  • any code for the AddDirSep(), RemoveDirSep() ?  I found some in VB forums, but they do not seem to match with their params.
  • Hi sarnold688,
    please find here the code of those two routines.
    Regards
    Thomas
    ' SUB: AddDirSep
    ' Add a trailing directory path separator (slash or back slash) to the
    ' end of a pathname unless one already exists
    ' IN/OUT: [strPathName] - path to add separator to
    ' Optional IN: [Forward] - switch to indicate which slash is to be added
    Public Function AddDirSep(strPathName As String, Optional Forward As Boolean = False) As String
    Dim gstrSEP_URLDIR As String
    Dim gstrSEP_DIR As String
      gstrSEP_URLDIR = "/"
      gstrSEP_DIR = ""
      strPathName = RTrim$(strPathName)
    ' Check if at the end the / is found
      If Right$(strPathName, Len(gstrSEP_URLDIR)) <> gstrSEP_URLDIR Then
    ' Check if at the end a is found
        If Right$(strPathName, Len(gstrSEP_DIR)) <> gstrSEP_DIR Then
    ' If no separator found add the right one depending on flag Forward
          If Forward = True Then
            strPathName = strPathName & gstrSEP_URLDIR
          Else
            strPathName = strPathName & gstrSEP_DIR
          End If
        End If
      End If
    ' Return resulting string
      AddDirSep = strPathName
    End Function
    'RemoveDirSep removes a trailing / or
    Public Function RemoveDirSep(strPath As String) As String
      gstrSEP_DIR = ""
      strPath = RTrim$(strPath)
    ' if one of the separators found
      If Right$(strPath, 1) = gstrSEP_DIR Or Right$(strPath, 1) = gstrSEP_URLDIR Then
    ' remove it
        strPath = Mid(strPath, 1, Len(strPath) - 1)
      End If
    ' return result
      RemoveDirSep = strPath
    End Function
