Reading cross connections with PCSDK
I am interested in reading the cross connection configuration from the robot using PCSDK. I can get the object for the ExternalIO configuration database, and I can get the object for the EIO_CROSS section, but I don't know how to read the individual entries, since they don't have a "name" attribute like the other config entries.
For example, my first guess would be to use get_Item(string name) and pass the resultant as the name, but that does not seem to work. Does anyone know how to do this?
Thank you.
  • Micky
    Micky ✭✭✭
    i have the same problem, but i want to read a rewrite the CountsPerMeter value from the EIO_COMMAND.
    EIO_COMMAND:
          -Unit "Qtrack1" -CommandType "CountsPerMeter" -Value "31118"
    It is possible to read the complete list for of the EIO-Commands, change the required parameter and write back the complete list to the robot controller ?
    Regards
    Micky
