Launch VC Locks Up RS5.11
Whenever the VC tries to start, RS5.11 locks up.  I have to 'end task' to get out of it.  I just received the new RS 5.11 and have the dump files if you need to view them.  Please help!
  • Hi Kevin,
                i think it is because of the wrong installation of the RS. Try to install the RS on another system. Before installing check the system date (Should be present date).
    Regards,
    Nikhil
