Set Position Doesn't work
Often if I right click on an element in HomeLayout, the "Set Position" item (and Rotate, place, ecc.) is disabled (grey). I dont understand why, because this command work properly in other time!!!
I'm using RobotStudio 2008
Can someone help me?
  • Hi Fulvio,
    RS 2008 was a "pre release" (not fully tested) with some known bugs. So I recommend that you install the latest RS version (5.11.01) and test again.
    ABB Robotics
