IRB660 Extended Work Range
Thomas J
Hello -
Please provide instruction/information on how to use extended work range in RobotStudio for IRB660 -
Created a system with the option Extended work range axis 1 +/-220 (which for some reason requires the Electronic Position Switch option 810-1 <-- please explain the requirement and what it is used for).
How do you get a VC/System in RS that can use the extended work range?
Creating a system with this option and launching the mechanism JOG control only gives you the standard +/-180 for axis 1.
We are attempting to show this functionality/option to customer for consideration of IRB660 for a de-palletizing/palletizing cell.
Thomas H. Johnston
PACs Application Engineer
Hello Thomas,
It is possible to run with extended work range in RS but you need to manually change the arm limits in the VC.
1. Create a system with option for 660 with extended wok range.
2. Start System
3. Go to Offline>Configuration>Motion>Arm
4. Change limits of axis 1 to +- 3.83972 (220 deg)
5. Restart controller => The limits of the RS model is now updated.
I don't know what you mean that the EPS option is required. I created a simple system as shown below.Best regards,
Anders Jahnberg, ABB RoboticsBest regards,
Anders Jahnberg
ABB Robotics0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
