demo palletizer querries
webwiz/2762/palletizing.zip
Please see uploaded video that is demo palletizer video from robot studio 5.11.
I wanted to make such video in robot studio.But How to make following efffects in robot studio ?
1 sack is automatically generated on first conveyor after few seconds .
2 sack is picked by gripper and is moving along gripper and is placed on pallet.
3 Pallet is seen moving on second conveyor.
reflex
  • Hi
    You need to make use of VSTA(write your own code, VB or C#) and the event table to be able to do a simulations like that.
    Per Svensson
    Consat Engineering
  • hi, reflex
    ehm.. yesterday i also make some simulation about palletizer. I'm not using VSTA, but instead using event manager. MAybe the simulation is not smooth as using VSTA, but it will be a alternative way to do a simulation. (actually, i don't know how to use VSTA, so i use event manager, Tongue)
    Good luck
    BR,
    indah carmila
  • Hi.
    1. Sack is made by vsta code tricked by event manager fro a DO.
    Here is the code for making a box
    Public Sub Macro_Create_Box()
    Dim Station1 As Station = Project.ActiveProject
    Dim box_origin As Matrix4 = New Matrix4(Vector3.XVector, 0.0)
    Here is the size of the box
    Dim
    box_size As Vector3 = New Vector3(0.2, 0.2, 0.2)
    Dim Part1 As New Part
    Dim Body1 As Body = Body.CreateSolidBox(box_origin, box_size)
    Station1.GraphicComponents.Add(Part1)
    Part1.Name =
    "Box_1"
    Here is the place of the box.
    Part1.Transform.X = 1.5
    Part1.Transform.Z = 0.78
    Part1.Bodies.Add(Body1)
    If Station1 Is Nothing Then
    Exit Sub
    End If
    Logger.AddMessage(
    New LogMessage("Macro_Create_Box is done."))
    End Sub
    2. Atchad the sack with event that atchad the neast object to your tool. trickt by a DO,
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • 3. You make a mecanicel device to transpot your pallet.
    Have Fun
    BR. Klaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
