Convert station from RS5.10 to RS4
I d like to ask, if it is possible to convert station from RS5.10 To RS4?
Best Regards for anybody who can  answer  to me
Thank You
ZombEe
  • No it is not.
    And why do you wan't to do that. RS 5.11 is big time better and works allmost prefect.
    BR Klaus
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • If I am right programs from RS5.11 will not fit to S4Csystems. True?And that is my problem.
    ZombEe
  • Hi,
    Programs from an IRC5 controller will run in an S4 contoller providing you do not use any commands that have been added to RAPID since the S4 release.
    Also you will need to have the same (or equivelent) RobotWare options in the S4 controller.
    If you look at the other way round it is probaly clearer, a S4 program will run in an IRC5 (providing the same Robotware options have been taken), because commands have been added to the later releases so there is no danger of using an unsupported command.
    Regards
    Graeme
