Move frame?
Hi!
I wonder how I can move the frame (the coordinate system's origin) relative to an object, because right now the frame is very far from the object and it makes repositioning very hard.
Thanks in advance for answers!
  • Hi,
    You can use Workobject
    In Wobj, you have two frame
    uframe => definition of the table (position and orientation)
    oframe => definition of the part on the table
    see help for more information (wobjdata)
    Give me more information if don't answer properly
  • Problem solved, thanks!
