hot edit
hi,
is hot edit only can edit the position in main procedure only? I have a main module that contain many procedures. ANd there are some robtarget that only called in a procedure outside the main procedure. when i want to edit this robtarget using hot edit, i can't. Hot edit only show the target that contain in main procedure.
is any way i should take to edit the target outside main procedure?
Thank you
BR,
indah carmila
  • Hi.
    The manual says that the targets has to be global. You can't edit them if they are declared local in a routine.
    BR/cba
  • So.. It's mean .. if i change the declaration LOCAL unto GLOBAL, I can edit them via hot edit? Smile I will try it.. (my computer is under repair, so I can't try now Cry)
    Thank you CBA!
    BR,
    indah carmila
