ODBC connection custom table [WebWare Server]
If you create a new custom table a ODBC-connection is automatically generated. If you now like to use a different user access instead of sa, e.g. NT User authentication it is not possible, because at every reastart the user level is set back to sa. Is this done by interlink or webware server? So what would be happen if I set in WWServer user auth. to NT user and I got Interlibnk on a different pc. Do I have to change ODBC-connection then manualy???
The SQL Server communication is handled by Webware Server.
As long as Interlink can communicate with WWService everything should be OK.I've done testing with 4.0.437 and I cannot reproduce the issue you are reporting (every restart of the machine). After changing the SQL Authentication level under Webware Database Admin page and rebooting the machine, the same authentication type is shown in Webware Server.
Please let me know if I've have understood your issue correctly.
______________________________
Anders Dannberg
ABB Automation Technologies
Support Engineer0
- 858 RAPID Programming
