Convert name of Work Object to a string
I am trying to convert the name of the current selected work object to a string to display in a uimsgbox. I know the load identify routine does it with tool data, and I wasn't sure how it was being done in that. Any help would be greatly appreciated.
Thanks,
Dustin
Dustin
  • I think ArgName does what you want.
    regards,
    Johannes
    Johannes Weiman
    Software Engineer
    ABB Robotics
  • Try
    [code]
    PERS wobjdata wobjTemp:=[FALSE,TRUE,"",[[0,0,0],[1,0,0,0]],[[0,0,0],[1,0,0,0]]];
    PERS string stTemp:="wobj0";
    PROC Main()
      GetSysData wobjTempObjectName:=stTemp;
      TpWrite stTemp;
    [/code]
    Where:
      wobjTemp
    is a persistent or variable that will have the value of the current workobject
      stTemp
    is a persistent or variable string that will have the name of the current workobject
    You can change wobjTemp  with a tooldata or loaddata to have the same effect with those datatypes.
    att.
    Rulv2009-02-22 04:16:51
