Conveyor Tracking
oscar_f
When I'm looking in the Conveyor setup Form, it is missing the Mechanical unit CNV1 and the workobject (see pic2.jpg)
I suspect that some configuration in the virtual controller is worng.
Could some one provide me the .cfg files to set up the VC for the conveyor tracking?
(The example with the paint robot is working correctly)
BR
Oscar
BR
Oscar Ferrrato
Oscar Ferrrato
Hi Oscar,In general the only configuration you need is to check the Conveyor Tracking Option in the SystemBuilder.PickMaster is not supported.Before you add the system, make sure you have a conveyor mechanism library on your file system. You will be prompted for it.Then you have to create a workobject and set the property MovedBy="CNV1" and, UfProg==false.Now the wobj should appear in the Conveyor Setup Dialog.Best RegardsNiklas Skoglund0
Thanks Niklas,I was using "prepered for pickmaster option"BR
Oscar Ferrrato0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
