RobotStudio 5.11.01 and 5.10
in 5.10, axis angle value on Virtual FlexPendant updates itsself when robot is moved by joint jog manually in Layout Mode (not jogged by using FlexPendant).
In 5.11, the value doesn't change when robot is jogged in any mode ( not jogged by FlexPendant).
Did I do something wrong?
  • Hi,
    No you have not done anything wrong, this is a known problem in 5.11. This problem will be corrected in the next release 5.12.
    ABB Robotics
