Event panel behavior
in ScreenMaker
While using ScreenMaker 5.11 CTP, I observed that it was not possible to change an action in the event panel, when the "show warning message" check box is selected. If you deselect the "show warning message" check box, you can make your changes. I don't know if this was the intended functionality or not.
No big deal.
Best Regards
Mark
Hi Mark,Thanks for the report.In the meantime, simple workaround ...1 - Make all changes in the actions and uncheck the warning
2 - Press OK
3 - Re-open Events panel, check the warning and press OKCarlos Martinez
ABB0
