Conveyor Tracking - Creating System
I have been trying to create a system using conveyor tracking and two conveyors but I keep getting the attached error message.
I have followed the directions in the user manual.  Import the geometry for the conveyor, create the conveyor mechanism with target points, save that mechanism as a library.  Than, create a system using system builder and when prompted for the library file I point to the conveyor and get the attached error "THE SYSTEM COULD'NT BE CREATED!".
Any help provided would be very much appreciated.
Thanks!
csydorko
  • Hi,
       Have you created Wobj frame while conveyor creation ?
    Regards,
    Nikhil
  • Hi,
    Sorry, I have no suggestion, but I also want to askBig smile
    Can an encoder interface (DSQC 377 A) track 2 different conveyor?
    If yes, is it need 2 encoder in 2 conveyors? I read in the manual, that an encoder interface only can support for an encoder.
    Here I attach the layout drawing. I need to track the objects in conveyor A, pick them and place them to the trays in conveyor B.
    can I track the conveyor A and B together in the same time?
    Many thanks.
    Carmila
    indah carmila
  • Maybe there is a problem with the system name, since it seems to be the same as the station name, try changing it to something different to see if that helps.
    Russell Drown
  • I got it working...for some reason, everytime I creating the system, it asked me for the conveyor library.  This caused duplicate conveyors in the systems.  If I created the system without the conveyors, it asked me for them and works fine.
    Thanks!
    Chris Sydorko
