Run Chain SS and GS
sturner
What is the difference between Superior Stop (SS), and General Stop (GS) run chains?
Also is it possible to activate a delayed, (smooth stop), usjing hese run chains?
Many thanks
sturner2009-03-10 12:47:28 0
Greetings,I believe that the system parameter default value for SOFT GS in an IRB 4400 or larger robot will be set to TRUE, which generates a delayed, controlled stop. All these settings may be changed by the user as necessary and safe.Lee Justice0
