RobotStudio 5.11.01 locking files
Hello, I make a small application in VS 2005 for Flexpendant, I add some instruccions to compiler for copy the files (dll) to my "home" directory. The first time works ok, but if I try to build the application again, I get a error from compiler, it say that can't copy the files to destination.
I close the virtual TPU  and I try to delete the files by my self, and I got a error that the files are in use. The same if I close RS.
Using unlocker program I can see that files are locked by Virtual controler. So I have to kill the procces using this software to be able to copy the new files.
How Can I make to avoid this mess?. If I close the Virtual TPU is not enough to release the files?, Close all RS and release the files "manualy" spends many time. Because RS takes a few time to starts up in my PC.
B.R.
/Jorge
Jorge Turiel
  • Hi Jorge,
    Try to shut down the VC, replace the DLL and start it again.
    regards,
    Johannes
    Johannes Weiman
    Software Engineer
    ABB Robotics
  • Hi,
    It should be enough to close the VTPU. Open the task manager and verify that you not have multiple "Virtual FlexPendant.exe" running. That have happened to me Ermm
    ABB Robotics
  • Hi,
    If you have this beviour constantly, you might have a memory leak, meaning that some of the classes used to access data from the RC5 are not "disposed" correctly
    BR
    Carlos Martinez
    ABB
  • Jorge
    Jorge ✭✭
    [QUOTE=carlosmtz2000]
    BR
    [/QUOTE]
    Hello, thanks eveybody for the answers. So I found the problem. I did a small aplication, only one button, and of course I made a dispose, and I don't have the problem, So I think, as said Carlos, I have a memory leak problem. But It's important, because my application, only is for testing and learning. So I have to see what I forget to dispose
    Thanks you everybody.
    B.R.
    /Jorge
    Jorge Turiel
