Why i can't import ".step" file
Rafeal
when i try to import a ".step" geometry ,will appear this message from picture!The file is about 50MB.But when i try to import geometry about 10MB,it is always successful.what's wrong?PLS help me. thank you!
Hi,Don't worry for that issue, it may be because of the part error. You have got many options.1. Use CAD converter in RS2. Open the same part in any of the Design software and save it agani with another nameand try to import.3. If it is not necessary to import the part as a *.STEP file then convert it to another formatand import.Regards,
Nikhil0
