Wobj name the same in Multple Robots
I have a six robot station and all the robots are using the same name for the Wobj. I noticed that when I synced the Paths to the station all of the targets went under the first robot. Can I use the same name for the Wobj in studio and get the targets to go with there corresponding robot?
Thanks,
Bob
When you use "Sync to Station" the program will automatically go to the "Active robot" which is the one with the controller started.
So before syncing start up the VC for the specific robot and you'll be fine.
When it comes to naming RS keeps track of all the names in the station regardless which robot it belongs to so unfortunately this means that it won't allow the same name in two different robots.
John
Developer Center0
- 858 RAPID Programming
