Hide application in ABB menu
I do not wish my ScreenMaker application to appear in the FlexPendant ABB menu.
Instead the screen must be displayed by my Rapid program using 'UIShow'.
I have tried using a blank icon and a blank caption in Project Properties, but if I click on the white space in the ABB menu the screen is displayed.
Is there a way to exclude the application from the ABB menu using ScreenMaker?
Thanks,
Kevin
  • Hi ...
    Try to remove the file: TpsApp*.gtpu.dll and try to UIShow RAPID instruction.
    Never try this my self, but it should work ..
    BR
    Carlos Martinez
    ABB
  • Kevin
    Kevin ✭✭
    Hi Carlos,
    I deleted my TpsApp*.gtpu.dll file from the VC then warm-started and launched the VFP.
    The application was not in the ABB menu, as expected, but UIShow caused an execution error because TpsApp*.gtpu.dll was not found.
    Could I leave TpsApp*.gtpu.dll in place, but manually edit it to prevent it showing in the menu?
    Any other ideas?
    Thanks,
    Kevin
  • You are right .. you are trying to launch the screen from that dll .. try this ..
    (1) This is your RAPID code:
    UIShow "ViewTest_Screens.gtpu.dll", "ABB.Robotics.SDK.Views.MainScreen";
    (2) Rename the file "TpsViewTest_Screens.gtpu.dll" to "ViewTest_Screens.gtpu.dll"
    This should work ...
    Carlos Martinez
    ABB
  • Kevin
    Kevin ✭✭
    Hi Carlos,
    That works OK.
    Thanks a lot.
    Kevin
