read output in VBA
I want to read an output from the active robotcontroller in my vba application in an IF THEN but it won't work.
Regards
Michael
Hi Michael
Here comes 2 different examples how you could do it.
The first one is just a simple read of IO from controller and
the second one reacts on changes on a specific IO.
1.
Sub ReadIO()
Dim mIO As IO
Set mIO = ActiveStation.ActiveMechanism.Controller.IO("doFinish")
If mIO.Value = 1 Then
MsgBox "Value is 1"
Else
MsgBox "Value is 0"
End If
End Sub2.
Dim WithEvents mIO As IO
Sub ConnectIO()
'Run this to start looking for changes
End SubPrivate Sub mIO_Change()
'This will execute if there is a value change
MsgBox "Value is 1"
Else
MsgBox "Value is 0"
End If
End SubHope this will help you
Regards
Per
Per Svensson
Company Specialist
ABB Automation Technology Products0
