hi.
I need a tutorial on how to create a multimove station in RS 5.10 with two robots doing different stuff. From A to Z .  Who know were can I find such tutorial. I tried to make an station myself but I need some help. Please!
Thanks
Cristian Gidinceanu
welder. engineer.
  • nobody knows or have the time to show me???
    Cristian Gidinceanu
    welder. engineer.
  • Hi,
    The Create Station from layout tutorial at this link http://www.abb.com/product/ap/seitp327/04a7e77286113ac1c1257427005a5498.aspx
    shows how to make a 2 robot with arc welding postioner station.
    Regards
    Graeme
  • Hello,
    If you know the 'Create System From Layout' option then you are 30% done with the step towards creating a multimove system. Just import the volume of robots you wana run in multimove (offcourse not exceeding 4) and just create system from layout and the system will create a system with multimove in-built.
    For example see below:
    T_ROB1 for robot1::
    PROC
    main()
    ID1:
    Home;
    MM1;
    GOTO ID1;
    PROC Home()
    MoveAbsJ jpos10, v1000, z1, tool0;
    PROC MM1()
    MoveJ p10, v1000, z1, tool0;
    WaitSyncTask sync1, task1;
    SyncMoveOn sync2, task2;
    MoveJ p20ID:=10, v1000, z1, tool0;
    MoveJ p30ID:=20, v1000, z1, tool0;
    MoveJ p40ID:=30, v1000, z1, tool0;
    MoveJ p50ID:=40, v1000, z1, tool0;
    SyncMoveOff sync3;
    T_ROB2 for robot2::
    PROC main()
    ID2:
    Home;
    MM2;
    GOTO ID2;
    PROC Home()
    PROC MM2()
    SyncMoveOff sync3;
    Regards,
    Saurabh Vashist
  • thank you
    Cristian Gidinceanu
    welder. engineer.
  • that's was verry helpfull. I did that and works fine.
    Cristian Gidinceanu
    welder. engineer.
  • that's was very helpfull. I did that and works fine.
    Cristian Gidinceanu
    welder. engineer.
