how to handle err of joint out of range
Zack
< ="-" ="text/; =utf-8">< name="ProgId" ="Word.">< name="Generator" ="Microsoft Word 12">< name="Originator" ="Microsoft Word 12">
Dear All
I have a question. In RS simulation, is there any way to
automatically handle and recover the err of joint out of range with either
Rapid or RS API. We need to run our simulation smoothly without any human
interference like manually jogging.
Dear All
I program a trap function to monitor joints angle and set
limits for them. If a joint is out of range, I use StopMove/quick function to
stop robot. But simulated robot still keep going when reach limit.
Can you help me with this problem.
Thanks
Zack
r u only setting the limits for each angle?
What about ur targets, those are all taught by the user or u are calculating each time?
If you are calculating each time, then u can calculate the joint limits by using, CalcJointT function to get joint angles.
Lingaa0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
