IRB 140T
Options
I am running RS5.11.01 and cannot start a system with an IRB140T. I can input the controller and robots seperately, but then they will not form a system.
Is this a bug in the system, my version of the software or other?
Any help would be appreciated.
Hello,I also found some other bugs in RS v5.11.01 Please upgrade with RS v5.11.02 for the time being. No such problems exists with this latest tested version.Although RS v5.12 is all set to be launched but for the time being this RS v5.11.02(stable version) can help you solve you problems.Regards,
Saurabh Vashist0 -
My colleague has 5.11.2 and it works on his system. But having installed 11.2 on my own system, I still can't get the 140T to work! Any other ideas?0
- 5.4K RobotStudio
- 384 UpFeed
- 14 Tutorials
- 12 RobotApps
- 291 PowerPacs
- 406 RobotStudio S4
- 247 ScreenMaker
- 2.7K Robot Controller
- 279 IRC5
- 46 OmniCore
- 3 RobotStudio AR Viewer
- 736 RAPID Programming
- 15 Wizard Easy Programming
- 105 Collaborative Robots
- 3 Job listings
