RS 5.11/5.12 in windows 64-bit
kuv-vokl
has anyone practical experiences with RS 5.11 or 5.12 based in windows 64-bit operating systems like XP 64-bit or vista business 64-bit ?
In the release notes i can read:
Note: RobotStudio 5.12 does not support 64-bit editions of Windows XP Professional or Vista Business or Enterprise
But: What does this mean ? - Is the software working (without the benefits of 64-bit), or not ?
Are there problems and limitations, or not ?
Please tell me your experiences.
Thanks to all.
Klaus
Klaus Vogel
Kühne+Vogel Sondermaschinen GmbH
Hi Klaus,We can not guarantee that RS will work correct with 64-bit OS. You may run into problem, specially with the Virtual Controller. Therefore are we not recommending 64-bit OS when you run RobotStudio.Best regards,
ABB Robotics0 -
Hi Anders,thank you for your hints. - That is what i have expectetd.But i want to know, if there are any experiences with it.Has anyone installed RS 5.11 or 5.12 in 64-bit system with or without problems ?I can not believe that i am the first user, interessting in 64-bit systems with RS.Many thanks for further posts.KlausKlaus Vogel
Kühne+Vogel Sondermaschinen GmbH0 -
Anders,are there any plans for Vista64bit support?Dean.0
I have installed it on Vista Ultimate 64 bit without any problems, I used the 30 day trial on my home computer without any problems as it was faster than my work laptop.I did have a couple of Virtual Controller crashes, but i get plenty of those running 32 bit anyway so I didnt see any extra problems because it was 64 bit (and having 8gb memory certinaly helped)0
Anders,
What problems exist on the VC specifically? I recently upgraded to Windows 7 64-bit and can't seem to get a PCSDK application to work...I keep getting an error related to the ABB.Robotics.Adapters.IRC5 assembly:
"Could not load file or assembly 'ABB.Robotics.Adapters.IRC5'" when doing a "new NetworkScanner()".0 -
Hi Dan,
A .NET application will run in 64-bit mode by default, but the PCSDK
only supports 32-bit operation. Therefore you must change the build
settings of the .exe to target 32-bit only:
Alternatively, if you can't recompile the app:
http://blogs.intesoft.net/post/2007/12/Running-NET-Apps-in-32-bit-mode-on-64-bit-Windows.aspx
regards,
Johannes
Johannes Weiman2010-02-09 09:35:35Johannes Weiman
Software Engineer
ABB Robotics0
- 40 AppStudio
