Reset UAS
norcar
How do I reset the UAS?
I have lost the rights to manage the UAS, I tryed to install a new system but that did not work!!
When I made the "Safety" user I forgot to make a user with the rights to manage UAS, from the beginning the "Default" user has that right but when you make a new user it is lost.
The default user should only lose the right to administer the UAS system if you have changed its group or the group's access permissions.
It is possible to disable the UAS system temporarily, but you must contact your local ABB support organization for instructions about how to do this.Russell Drown0 -
HiFor recovering UAS administration rights start a terminal program and type the command: uas_disable.Best Regards0
