FileList Property [WebWare SDK]
what is the maximum character length of a file name?
I tried to copy a file "abcde_abcd.sys" but the S4Dir.FileList only shows me "abcde_abcd.s"
It gives me a -3102 fault.
If the maximum is 8+3 then how can I get around it without renaming my file?
Thanks
E.B
  • Hello,
    This is a limitation in RAP (Robot Application Protocol) which WebWare use to communicate with S4 robots.
    If your robot is set up to handle FTP (server), try going into Interlink Configuration Utility -> Edit the profile you are using -> Goto FTP tab -> Select Enable FTP Interface and enter login credentials. This should allow you to view long filenames using the S4Dir.Filelist.
    ______________________________
    Anders Dannberg
    ABB Automation Technologies
    Support Engineer
