NoBot
Want to use an IRC5 controller to operate all of our attachments WITHOUT the robot being present....   ie like a test stand.    Any Idea on how to create that type of system?
Mike Kegley
  • .... put another way.... Can you use an IRC5 controller without connecting a robot to it?...
    or...
    Is there a way to run Rapid code in a real IRC5 control, while the physical robot arm is disconnected?...
    Mike Kegley
  • You need a special drive key that will allow you to select no manipulator. You can order the robot this way or contact your local ABB support organization to obtain a new key.
    Russell Drown
