Search & Replace in View Only Module
Daak
A field Programmer has reported a inconsistant behavior within Rapid Editor VS Search & Replace function (CTRL+F) in RS 5.12.
While Changing Globally the Label "Task" to "Cmd" in his application program while active with controller using the Search and Replace against system the Base.sys module which is View Only was altered.
Reverse of this effect could not be performed due to editor access denied on basis of view only declaration in file. I-start was performed to system to clear and regenerate base.sys, but programmer was intrested if this was a known bug in the interface.
Kirk "Daak" Rich
