Search & Replace in View Only Module
Daak
ABB field programmer reporting:
Ctrl+F search and replace to system is able to perform on text within View only modules in controller with write access permission active from RSO by selection of within system.
Since this is not permissable in normal Rapid Editing will future updates to the RS/RSO package take measure to block this editing action on condition set modules?
Searching: a case example | Assume that you have programed targets and motion instructions and sychronized them to the controller. The number of targets is large, so you decide to distribute them among several modules.You may have forgotten in which module your main procedure is found.
Kirk "Daak" Rich
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
