Error message [ArcWelding PowerPac]
I have been getting an error message that reads:
"Do you want to automatically load all un-installed instruction templates in the default directories? Only instructions NOT present in the station but present in the VC will be imported. Default directories: SYSTEM/HOME/RS/RobotStudio/ProcessPac/"
And then I have to choose Yes/No/Cancel.
What is causing this error and is there a way to remedy it?
  • To be able to create instructions in RS or AWPP you need templates. So when starting a station the first time with AWPP there is a question if you want to max load your station with a lot of arc related templates. This is not an error this is a help! So my suggestion is to answer yes to the question.
    BR / Andersson
